Author Topic: biting point  (Read 1390 times)
Offline so1o
biting point
« on: 02 October 2004, 23:06 »
Help!
My biting point on my mk2 2.0 16v (9a) is to high. This doesnt sound like much of a problem but its damn annoying.
I took it to one place but he said cant do nothing about it???? Is this true or can i adjust it to make it lower?
Its a fairly new clutch aswell.
Solo
Offline richandhazel
Re: biting point
« Reply #1 on: 03 October 2004, 15:31 »
Is it an auto adjusting cable or manual adjustment? With manual adjustment you should be able to put some slack in the cable to make it bite lower.
If its the auto adjusting type resetting it may help :-\
Offline so1o
Re: biting point
« Reply #2 on: 03 October 2004, 15:49 »
Its a manual adjustment one, i did try once but to no avail. I was thinking, could it be something else? Or just needs a proper adjustment.
Re: biting point
« Reply #3 on: 03 October 2004, 16:15 »
I think it probably just needs adjustment. You should have around an inch of pedal movement (free play) before the cable actually operates the clutch.
Thats the case for the 8V anyway, fairly certain this will be similar. Try slackening it off until it moves down to where you want it.
Offline so1o
Re: biting point
« Reply #4 on: 04 October 2004, 00:20 »
Cheers mate, will give it a go.
