Author Topic: Odd findings with idle  (Read 971 times)
Offline maxp
  • J reg 8v digi gti
« on: 08 November 2009, 11:59 »
Basically if i disconnect power to the idle switch / throttle valve switch, the revs shoot up to 1900rpm straight off the bat.
When reconnected it sits at a nice 900rpm ish.
Idle screw has been checked ok  - can basically close it and it will make only a small difference.
Advice appreciated.
« Last Edit: 08 November 2009, 13:30 by maxp »
Offline Alec
Re: Odd findings with idle
« Reply #1 on: 08 November 2009, 13:32 »
Whats the actual idle problem? you say it idles nicely at 900 when everything is connected
Offline maxp
  • J reg 8v digi gti
« Reply #2 on: 08 November 2009, 13:44 »
It means when i remove the idle switch from the equation, i have a car that revs at an absolute minimum of 1900rpm (i.e. at >2% throttle, when the idle switch is no longer pressed)
Offline Alec
« Reply #3 on: 08 November 2009, 15:36 »
Oh right lol thats a bit of a pickle. Dont think I am gonna be of much help on that one lol. These old golfs seem to have alot of idle problems judging by what I see on here
Offline bodga
  • F reg GTI 16v
« Reply #4 on: 08 November 2009, 16:32 »
Italian tune up! :grin: google it for instructions, these old cars need the dust and cob webs removing once in a while. it fixed my coughs and splutters anyway. make sure your car is up for it first thou, check fluids etc
Offline maxp
  • J reg 8v digi gti
« Reply #5 on: 08 November 2009, 16:57 »
The car runs fine, does good mpg (40-45mpg), its just the revs hike to 2000rpm not 1000rpm when the throttle has past 2% open.
« Reply #6 on: 09 November 2009, 09:20 »
check your other thread!
