Author Topic: Correct tyre pressures ???  (Read 2295 times)
Offline Burnsy
« on: 01 October 2004, 13:51 »
Just been to pump my tyres up at the local garage and according to the "Michelin" guide it states that the Mk 3 Golf Vr6 tyres should be pumped up to 38 psi on the front and 35 psi on the rear.
This seems a bit excessive to what ive normally used on previous cars ive owned.
Does anyone know if these are correct ?
TiA
Offline tobz.
Re: Correct tyre pressures ???
« Reply #1 on: 01 October 2004, 13:59 »
Not sure if that's correct but you should find a sticker on one of the door pillars which will give you the tyre pressures.
You got any pics of your dad's split ?
Offline Overseer
« Reply #2 on: 01 October 2004, 14:48 »
the sticker is inside the fuel flap on my car :)
mid 30s sounds about right though..
Offline tobz.
« Reply #3 on: 01 October 2004, 14:54 »
Oh yeah I forgot they put if the fuel flap on some models.
I would say that high pressure could be right as the vr6 is a pretty heavy engine.
