Golf mk3
hardmonkeys
radiator fan fuse
Topic: radiator fan fuse (Read 2182 times)
arthur daley
work to live not live to work
radiator fan fuse
04 November 2009, 15:48 »
mine keeps blowing at the point that it should come on and my temp gauge isnt working.ive unplugged the fan to see if it was a short in the motor and still no good and checked the fuse on the turret under the coolant bottle and also had a look at the wireing and cant see anything.has anyone got any ideas please
gtigolfthree
Guest
Re: radiator fan fuse
04 November 2009, 15:54 »
Mabye the value (amperage) of the fuse you are using is too low.
Wayne
Sir Postalot
04 November 2009, 16:03 »
I would suggest you have a sender problem if the gauge is not working.
arthur daley
04 November 2009, 17:01 »
is the sender on the rad near the fan?
gtigolfthree
Guest
04 November 2009, 17:10 »
No its on the engine, what engine is it?
arthur daley
04 November 2009, 17:13 »
dunno lol k reg 2l gti 8v if that helps is it a single wire sensor on the end of the engine?
gtigolfthree
Guest
Reply #6 on:
04 November 2009, 18:40 »
Probably a 2E engine take the wire off the sender unit and touch it to earth, if the gauge goes to the top, the sender unit is faulty
arthur daley
Reply #7 on:
04 November 2009, 18:44 »
cool thanx mate would that be whats making the fan fuse blow?
gtigolfthree
Guest
Reply #8 on:
04 November 2009, 18:48 »
No, unrelated, as I mentioned earlier check the fuses rating. The fan uses a lot of power.
arthur daley
Reply #9 on:
04 November 2009, 18:51 »
it is a 30 amp and i have been using the right fuses and also when the fans meant to be running on after uve turned off the ignition it still blows the fuse
Golf mk3
hardmonkeys
radiator fan fuse
