Author Topic: rad pipes for abf  (Read 1045 times)
Offline richard s
rad pipes for abf
« on: 02 November 2009, 15:08 »
almost there with abf just rad pipes and heater matrix to do as i found out earlier mine dont line up is it just a case of fitting a mk2 16v top hose and flange
and does the rad fan touch the engine multi plug on anyone elses
clutch cable what you guys used as my ibiza one is auto adjusting and is almost touching rad fan wiring and i can see it rocking about into something due to the big weight on it so would like to change it
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
Re: rad pipes for abf
« Reply #1 on: 02 November 2009, 18:32 »
there is a bracket you can buy which attaches to the water bottle. Its about £10 from seat
Offline richard s
« Reply #2 on: 02 November 2009, 19:39 »
what model would the bracket be for or do you have a part number
also does the corrado kr have the same pipes as the mk2 kr
cheers
« Last Edit: 02 November 2009, 19:43 by richard s »
« Reply #3 on: 03 November 2009, 12:52 »
what managment are you using?
Offline richard s
« Reply #4 on: 03 November 2009, 19:57 »
standard abf management
« Reply #5 on: 03 November 2009, 20:49 »
Its for the seat toledo abf
« Reply #6 on: 04 November 2009, 10:00 »
right you have to use the ABF front flange, the KR/9a one fowls on the inlet. then mess about with a few hoses till you find one that fits.
as for the bottom you need a std MK2 thermostat flange and bottom hose
Offline richard s
« Reply #7 on: 04 November 2009, 13:22 »
cheers guys
