Author Topic: starting probs  (Read 1469 times)
Offline storky
starting probs
« on: 02 November 2009, 09:52 »
Hi all,
Spent the weekend changing the engine on my PB 8v and now having probs starting.
Tried turninng over last night. Made a bang through the exhaust burning off petrol. Now there is no spark? Guessing that something ain't right but can't see what. Anyone got any ideas please.
Thanks
Offline Ben Lessani
Re: starting probs
« Reply #1 on: 02 November 2009, 13:26 »
Firing order - lets go 2 for 2
Offline storky
Re: starting probs
« Reply #2 on: 02 November 2009, 14:24 »
when changing engines we had to fit the power steeriing pump onto new engine. This involved swapping pulleys which interfered with cambelt. Think it is the timing?
Offline Ben Lessani
Re: starting probs
« Reply #3 on: 02 November 2009, 15:16 »
Re: starting probs
« Reply #4 on: 03 November 2009, 12:59 »
turn the key 1 click, does your fuel pump run for a few seconds or just go continuously? if it just runs constantly, you have blown up your ECU. check the battery earth, this needs a good electrical contact to the gearbox or box mounting bracket, or your ecu will die.
Offline storky
Re: starting probs
« Reply #5 on: 03 November 2009, 21:27 »
ok i.ve had another look and there is a spark. Will check the fuel pump though. Got someone coming to look over it thursday so hopefully we'll crack it.  :laugh:
Offline Thom89
  • Looking for an "Icebreaker"
Re: starting probs
« Reply #6 on: 04 November 2009, 00:00 »
Groundhog day!
Thom
Offline storky
Re: starting probs
« Reply #7 on: 04 November 2009, 12:30 »
Offline Ben Lessani
Re: starting probs
« Reply #8 on: 04 November 2009, 13:22 »
It sounds like you have put the spark plug leads on in the wrong order, it happened to someone else same day - hence the groundhoglyness.
Offline storky
Re: starting probs
« Reply #9 on: 04 November 2009, 17:14 »
   aah ok. Have checked the plugs and they were def in the right order. Confused.com!! :undecided:
