Author Topic: what brakes are these?  (Read 1407 times)
Offline dr.gonzo
« on: 02 November 2009, 08:06 »
originaly i thought audi tt but ive just seen a r32 with what looks the same but a search for r32 calipers finds calipers with standard hoses, mine have banjo fittings.
anyone any idea?
Offline Ess_Three
Re: what brakes are these?
« Reply #1 on: 02 November 2009, 09:10 »
They are the ATE callipers from a late GTI - 288mm I'd say.
Same callipers as TT/S3 but they won't be 312mm discs as they won't fit under 15" wheels...so must be 288s.
..but gaining motorcycles.
Offline dr.gonzo
« Reply #2 on: 02 November 2009, 09:57 »
Late as in mk4?
I wish I'd known before I bought hoses all round!
Cheers mate, at least I know before I buy the wrong pads aswel.
Offline Ess_Three
« Reply #3 on: 02 November 2009, 10:01 »
Late as in mk4?
No, late as in late Mk3.
Mk4 callipers (288s) are the same, but Mk4 discs have a 6mm larger offset...so Mk4 288s or Mk4 312s/TT 312s/S3 312s will all fit but all need a 6mm spaced between the calliper carrier and hub...and 6mm longer bolts to fasten the lot together.
As far as I'm aware, TT/S3/4 Motion 312mm ATE callipers, Mk4 288mm ATE callipers and late Mk3 288mm ATE callipers are all the same, and use the same pads.
« Reply #4 on: 02 November 2009, 10:02 »
288's were standard on later mk3's my 1996 was the same set up.
Offline Paul86S2
« Reply #5 on: 02 November 2009, 11:59 »
Late as in mk4?
The only differance in the Mk4 onwards ATE calipers is that the flexi hose connection is in a differant place to the late Mk3 ones.
Paul
