Author Topic: complete mare of a day  (Read 1705 times)
Offline maxp
  • J reg 8v digi gti
« on: 01 November 2009, 18:19 »
Broke down on the m25 whilst it pissed it down this morn. found out lead 2 was arcing massively at the cap. 1x new lead later, car starts juddering a bit, had a look under thwe bonnet and there are now a small blueish spark at the plug end of lead 3 and the battery led on the dash is flickering real dimmley when the car idles. Any ideas?
Offline Horney
Re: complete mare of a day
« Reply #1 on: 01 November 2009, 18:23 »
You need a full set of new leads and check the alternator belt is tensioned correctly.
nick
Offline AudiA8Quattro
« Reply #2 on: 01 November 2009, 18:24 »
Also a new cap and rotor arm.
Offline maxp
  • J reg 8v digi gti
« Reply #3 on: 01 November 2009, 20:09 »
Can anyone offer insight into whats creating the constant blue spark (at the very bottom of the lead / where the rubber end meets the head)
Offline Horney
« Reply #4 on: 01 November 2009, 20:12 »
It'll be the rubber perished on the lead and the lead arcing out onto the block.
Nick
Offline maxp
  • J reg 8v digi gti
« Reply #5 on: 01 November 2009, 20:15 »
That is pathetic, they are only about 10 months / 8,000 miles old!
« Last Edit: 01 November 2009, 20:17 by maxp »
Offline Horney
« Reply #6 on: 01 November 2009, 20:16 »
I've had this happen with a brand new set of cheap leads from GSF and have found the cheaper leads to be generally rubbish on 8v's. I now only buy pukka OEM quality leads and they last much better.
nick
Offline maxp
  • J reg 8v digi gti
« Reply #7 on: 01 November 2009, 20:18 »
I think these may have come from GSF (look abit like oem with the metal jacket round the rubber at the plug end, but cheapy rubber at the cap end).
Ordered a set (beru) from vwspares this morn on recommendation of this forum. Worth a punt at £20 for 4.
Do you remember how much you paid for the OEM?
Offline Horney
« Reply #8 on: 01 November 2009, 20:22 »
The beru ones are OEM quality and they're the ones I run on my track car (and on the Rado when I had it).
nick
Offline Jay
  • balding fat cvnt
« Reply #9 on: 01 November 2009, 21:30 »
The battery light flickering @ idle could be the voltage regulator in the alternator, mine does this and I should sort it out really...
