Author Topic: Removing a Pre 90 Mk2 steering lock  (Read 1139 times)
Offline acox99
« on: 01 November 2009, 16:12 »
Does anyone know how to do this, i have read the haynes manual and it just confuses me.
Offline Sam
  • Sam I am
Re: Removing a Pre 90 Mk2 steering lock
« Reply #1 on: 01 November 2009, 16:27 »
HIT IT!!
Offline bodga
  • F reg GTI 16v
« Reply #2 on: 01 November 2009, 21:21 »
If you havent a key, or lock is knackered the only way is.
Remove the steering wheel, column stalks and the spring and locking washer from in front of the column bearing. WATCH THIS SPRING, IT WILL HAVE YOUR EYE OUT!  :sick: i held one of my old t shirts over the column shaft and spring whilst i prised the washer off. take the fusebox cover/lower tray off, bottom ign cowl off, remove the bolt clamping the ign casting to the steering colomn. then prise the casting off where the bolt was, not easy and you might damage the top cowl. but it can be done. u aint stealing it r u??? :laugh:
Offline acox99
« Reply #3 on: 02 November 2009, 22:54 »
No im building a track car and the require it to be removed
Offline Sam
  • Sam I am
« Reply #4 on: 02 November 2009, 23:25 »
If its a track car surely you can just rip it all out/smash it off??
