Author Topic: Think my car's haunted.........  (Read 2785 times)
Offline ABOO
« on: 31 October 2009, 21:04 »
Yesterday on way to work opened car in morning, before I started it my locks sounded like they were trying to lock the doors, but never did, and interior lights came on. While driving to work [only 10 mins], this happened a couple of more times.
Then when coming home, car died on me 3 times. Revs seemed to stick, wouldn't go up when accelerating, then revs just dropped off and car died. Started straight up again, and was back to normal. Engine management light is now on all the time, have done a scan and lists 14 codes. This is from last week as ecu was cleared after another issue.
Been to work in it today, em light on, performance as normal, hasn't died on me but locks still sound like they're trying to lock and unlock.
WTF is going on!!!!!!!!!! :sad:
Codes are...17633,17655,17636,17634,17833,17955,17843,17938,17829,17697,17525,17522,16486,17524 :cry:
2001 aum 1.8T
Offline Steve_PD
Re: Think my car's haunted.........
« Reply #1 on: 31 October 2009, 21:11 »
17633 - no match
  17655/P1247/004679 - Needle Lift Sensor (G80): Open or Short to Plus
Possible Symptoms
    * Malfunction Indicator Light (MIL) ON
    * Pre-Glow Light ON
    * Rough Engine Performance
    * Excessive Emissions
Possible Causes
    * Fuse(s) faulty
    * Wiring and/or Connector(s) from/to Needle Lift Sensor (G80) faulty
    * Needle Lift Sensor (G80) faulty
Possible Solutions
    * Check Fuse(s)
    * Check Wiring and/or Connector(s) from/to Needle Lift Sensor (G80)
    * Check/Replace Needle Lift Sensor (G80)
17636-no match
17634-no match
17833-no match
  17955/P1547/005447 - Boost Pressure Controle Valve (N75): Short to Ground
Possible Symptoms
    * Irregular behaviour
    * Loss of power
    * Limp mode
Possible Causes
    * Wiring and/or connections faulty (short circuit)
    * N75 faulty
Possible Solutions
    * Check wiring and connections
    * Check / Replace N75
  17843/P1435/005173 - Secondary Air Pump Relay (J299): Short to Ground
Possible Causes
    * Secondary Air Pump Relay (J299) faulty
Possible Solutions
    * Check Secondary Air Pump Relay (J299)
17938-no match
  17829/P1421/005153 - Secondary Air Injection Solenoid Valve (N112): Short to Ground
Possible Causes
    * Secondary Air Injection Solenoid Valve (N112) faulty
Possible Solutions
    * Check Secondary Air Injection Solenoid Valve (N112)
17697-no match
17525-no match
17522-no match
16486-no match
17524-no match
Offline topher
  • Administrator
  • fully functioning
« Reply #2 on: 31 October 2009, 21:15 »
could be a lot of things, hard to say without seeing the car.. but the first thing i'd check would be the fuses on top of the battery (then the rest of the fuses..) And then all the earthing points, there's a guide on here somewhere for all the earth locations if you search
Offline ABOO
« Reply #3 on: 31 October 2009, 21:16 »
Cheers for codes Steve. Fault last week involved wiring so looking at some of the possible solutions, that could be where my issues still lie. Returning it to garage Monday dinnertime,so we'll see.
Thanks again... :wink:
2001 aum 1.8T
Offline ABOO
« Reply #4 on: 31 October 2009, 21:18 »
Cheers Topher. I know one of the relays on battery is a dual fuel-pump and ecu relay, so that may be something to look at...
2001 aum 1.8T
Offline jimbooboo
  • YUM YUM
« Reply #5 on: 31 October 2009, 21:36 »
Now, I'm no paranormal activity expert, but I'd say your car is haunted by the ghost of the disembodied auto electrician.
Offline golf-sib
  • Турботазик
« Reply #6 on: 01 November 2009, 00:09 »
 :huh: eh?.... maybe its just trying to say, happy halloween?   :tongue:
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline ABOO
« Reply #7 on: 01 November 2009, 20:16 »
The plot thickened today...due to issue with door locks, thought I'd use the spare key.
No engine management light, no random lock action, run sweet as a nut!!!!
2001 aum 1.8T
