Author Topic: I need a dummys guide to fitting fiscon please  (Read 4423 times)
Offline Das Auto
« on: 31 October 2009, 16:02 »
Can somebody tell me how to fit this thing I have just bought please as the instructions dnt help. Do I have to attach any wires or do the black boxes just plug in ???
Thanx in advance
Offline mac7
Re: I need a dummys guide to fitting fiscon please
« Reply #1 on: 31 October 2009, 17:19 »
Use the Search tool - there's loads of info in here and (I think) the Mk5 section.
Golf R
Offline gossa
« Reply #2 on: 31 October 2009, 17:43 »
Das, who is going to code it for you? You need someone with VAG.com to activate the phone kit (2 minute job, ticking a box on a computer screen).
Are you reasonable competent mechanically? Got torx bolt sockets/drivers?
Offline Das Auto
« Reply #3 on: 31 October 2009, 17:55 »
Vw are going to activate it for me and I have the torx screws but I'm not exactly clued up with electrics
Offline gossa
« Reply #4 on: 31 October 2009, 17:58 »
Mate, i might suggest getting them to fit it for you if you're not sure.  For someone mechanically minded it looks very straight forward so if you can't figure it out by looking you might be better off paying them (no more than 1 hour labour though!!). Not saying your NOT mechanically competent though fella!!
If you fancy it yourself i'lll dig out my old thread on fitting it and post in here.
Offline gossa
« Reply #5 on: 31 October 2009, 18:07 »
OK, there's some info here
http://www.golfgtiforum.co.uk/index.php?topic=124452.0
First, remove headunit facia plate (I used a blunt cutlery knife). Prise the cover off gently as it snaps into place.
Now remove headunit with the four torx bolts
Now unplug the headunit, plug in the fiscon, plug the leads back into the fiscon plug
Wrap the bluetooth box in bubble wrap to stop it rattling when positioned behind the headunit.
Plug the mic into the box and route the cable down through the dash cavity and locate mic where you please.
Bolt it all back together, probably need to recode stereo as well as set up the phone on vag.com
Offline Das Auto
« Reply #6 on: 31 October 2009, 18:08 »
Vw are fitting it for me but they said we never seen it before and we don't know how to fit it ?
Offline Das Auto
« Reply #7 on: 31 October 2009, 18:12 »
I wouldn't have a clue with the micraphone how do u get it to come up through the a column ?
Offline gossa
« Reply #8 on: 31 October 2009, 18:23 »
VW are fitting it and they can't figure out how????? I'm sure a decent mechanic will have it in in 15 mins.
As for the mic, I just slipped mine inside the door seal rubber. Primitive but it works...
Offline AlanH
« Reply #9 on: 31 October 2009, 22:41 »
Try Googling for "Fiscon installation manual" and you should come across a couple of pdf guides. Had mine fitted today, but it doesn't come with any kind of owner's manual. Fortunately the fitter knew his stuff and we had it set up and synced to my phone in 10 minutes.
Mk7 GTD | 3-door, Carbon Grey, Keyless, Dynaudio, Pano roof.
