Author Topic: mk3 glof gti 8v  (Read 2128 times)
Offline brett1975
mk3 glof gti 8v
« on: 31 October 2009, 09:01 »
Hi all, been reading forums for while and decided to ask for help, i have a 96 golf gti 8v and recently it had no power over half throttle so i replaced to maf sensor and it brilliant, well for an 8v, lol.
but now i only getting 23 mpg if i only touch the throttle, can any one shed any ideas as i out of ideas, and petrol.
Offline brett1975
Re: mk3 glof gti 8v
« Reply #1 on: 31 October 2009, 09:17 »
and the idle also occasionaly become erratic and wants to stall but dosnt at times, also how do i upload pics of my car for peeps to see.
Offline justalex81
Re: mk3 glof gti 8v
« Reply #2 on: 31 October 2009, 10:34 »
if you use the search function you will find all your answers!
Offline brett1975
Re: mk3 golf gti 8v
« Reply #3 on: 31 October 2009, 13:49 »
Thanks for advice, mine does 23 when booting it, and about 30 mpg when being careful, is this normal?
Offline brett1975
Re: mk3 glof gti 8v
« Reply #4 on: 31 October 2009, 14:32 »
it was o2 sensor thanks for advice
Offline brett1975
Re: mk3 glof gti 8v
« Reply #5 on: 31 October 2009, 14:35 »
Re: mk3 golf gti 8v
« Reply #6 on: 01 November 2009, 00:23 »
Yes, my 8v was around the same did better on a long run however.
Offline Vigilante
Re: mk3 glof gti 8v
« Reply #7 on: 01 November 2009, 10:24 »
I'm getting about 33mpg booting it, and if I'm careful can get over 40.......but silly careful, know what I mean......? Averages around 35 between fillups  :smiley:
Offline bored_Welsh_lad
Re: mk3 glof gti 8v
« Reply #8 on: 01 November 2009, 12:07 »
i took the 8v out for the first time since getting back from afghan in sept.. i did a run from swansea to yorkshire and pulled a 44mpg av. on the mfa.. i did 70 all the way though..
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
