Author Topic: lambda sensor  (Read 864 times)
Offline turboblack
lambda sensor
« on: 30 October 2009, 18:18 »
A question for anyone that knows i have a mk 4 gti 1.8 turbo agu engine the car has a straight through stainless mongoose system with no cat just been for mot and failed idle test. I have now bought a new cat to go on but this has 2 threaded holes in it either side of the cat which i belive is for the lambda sensor as i do not have a sensor can these be blanked off as i only need this to pass mot and will be back off the car after the mot help please.
Offline richw911
Re: lambda sensor
« Reply #1 on: 30 October 2009, 19:17 »
Has the lambda sensor has been mapped out.{Not sure you can on an AGU  :undecided:}
AGU only has one sensor  :wink:
Offline turboblack
Re: lambda sensor
« Reply #2 on: 30 October 2009, 19:20 »
don't know cant see a sensor on car at the mo but car has been retuned before i owned it and just need to know if car will run with the cat to pass mot
