Author Topic: help with immobiliser  (Read 1086 times)
Offline ginga
« on: 30 October 2009, 11:09 »
hi
im installin a new glovebox into my vr.
problem is there is the immobiliser. question is what will happen if i disconnect it?
Offline Deano2711
  • 1992 VR6
Re: help with immobiliser
« Reply #1 on: 30 October 2009, 11:20 »
Hi Mate     If you disconnect it without starting the car then it may well mess up. The best thing to do is start the car and while it's running disconnect it. Should be ok then.     Hope this helps     Deano
« Reply #2 on: 30 October 2009, 11:25 »
I would be really carefull doing it that way as you could blow it, better to disconnect the battery then the immob. unit.
Offline Deano2711
  • 1992 VR6
« Reply #3 on: 30 October 2009, 11:28 »
There's something I have learnt. I have always done mine with the engine running....just lucky then really!!!!!!!  Cheers     Deano
Offline Mikester
  • Civic Type R
« Reply #4 on: 31 October 2009, 19:04 »
Or get an alarm specialist to sort it out properly.
