Author Topic: Exhausts  (Read 4174 times)
Offline axewielder
  • 95 dragon 8v
Re: Exhausts
« Reply #10 on: 30 October 2009, 10:49 »
Back pressure is caused by using too large a diameter! So fitting a larger exhaust causes the gasses to slow down, THAT is what causes back pressure!
i was pretty sure smaller bore=more back pressure as it restricts flow and therefore helps stop the engine blowing fresh charge straight out the exhaust port on the overlap
big bore=less back pressure which is good for turbos ect as it is less restriction and increased flow + gas speed to help turbo spooling
if its just cat back system there will still be the origional bore on the first part of the system so wont do anything drasticly massive to the engine performance either way
Offline Adam
Re: Exhausts
« Reply #11 on: 30 October 2009, 10:50 »
A NA engine relays on back pressure
Down Hill From Here.
Re: Exhausts
« Reply #12 on: 30 October 2009, 10:51 »
I am thinking the same.
Offline VR6-Joe
Re: Exhausts
« Reply #13 on: 30 October 2009, 11:42 »
Thanks for the replies, I see some of you are concerned about the damage that my happen to my engine :huh:
The exhaust is a stainless steel cat back system off a 16v
So far from this thread I've established the 16v/VR6 exhaust is 2.25" (thanks Mike) .. my 1.6 is a 1996 if that makes any difference to the size of my exhaust? I would measure it but it's on the car and I'll be needing the car to go to a tyre/exhaust place to buy a reducer lol.
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline Mikester
  • Civic Type R
Re: Exhausts
« Reply #14 on: 30 October 2009, 11:45 »
You can measure it on the car ok.
I know that a 1.8 GL like shadys uses the same as a 8v gti bore, which is 2inch.
But im not sure about yours, i would look on a parts website and see if the exhaust parts are listed the same for a 1.6 and 1.8. That way you will know if it will fit.
Offline axewielder
  • 95 dragon 8v
Re: Exhausts
« Reply #15 on: 30 October 2009, 11:50 »
no damage, just noise+shift the power band up a bit, might reduce overall power by 0.1hp too if ure lucky  :smug:
Offline justalex81
Re: Exhausts
« Reply #16 on: 30 October 2009, 21:51 »
i'm gonna put a ferrari exhaust on mine. should add at least 300bhp to my abf  :rolleyes: :laugh: :grin:
Offline Cable
Re: Exhausts
« Reply #17 on: 30 October 2009, 21:53 »
Nah they add 400bhp  :wink:
Offline justalex81
Re: Exhausts
« Reply #18 on: 30 October 2009, 22:54 »
oh in that case i'm gonna stick bugatti veyron wing mirrors on it. should be good for 9000 torques  :cool:
Offline Cable
Re: Exhausts
« Reply #19 on: 30 October 2009, 23:25 »
haha, yh 0.90000 torques
