Author Topic: Anyone fitted a ko3s to a pre 2000 1.8T (150)?  (Read 1470 times)
Offline Chris192
« on: 29 October 2009, 17:01 »
Quick question - has anyone fitted a k03s to a pre 2000 1.8T (150) which has the k03 as standard? how hard is it and does it require any new parts from VW? Also whilst on the subject - if you have had a R-Tech remap done to the car whilst it has the ko3 would it a new remap done after fitting the ko3s?
Thanks in advance for help!
Chris
Offline Steve_PD
Re: Anyone fitted a ko3s to a pre 2000 1.8T (150)?
« Reply #1 on: 29 October 2009, 17:07 »
yes, wazzzer, ivor and patch has.
you will need a new map
Offline DarkGti
« Reply #2 on: 29 October 2009, 17:08 »
and me! heres noonoo's guide
http://uk-mkivs.net/forums/t/265756.aspx
Offline Chris192
« Reply #3 on: 29 October 2009, 18:40 »
Cheers buddy exactly what i was after :)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 29 October 2009, 20:15 »
If you're doing it yourself be prepared for a big job, myself and Patch found it very time consuming and fiddly
Offline monzablue16v
« Reply #5 on: 29 October 2009, 21:26 »
Just done it, unbolt old one bolt up new one, but my engine is already out and on an engine stand. Replace the two gaskets and the studs/bolts from turbo to downpipe :)
Edit:follow that how to, but for the extra few bolts and jubilees to drop the engine out it's a hell of a lot easier :)
« Last Edit: 29 October 2009, 21:32 by monzablue16v »
Offline Grand Master Patch
« Reply #6 on: 29 October 2009, 21:54 »
Mine made 212bhp after i fitted the ko3s,that was using the stage1 map.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 29 October 2009, 22:29 »
that's cheating  :laugh:
« Reply #8 on: 29 October 2009, 23:48 »
It is but you can do other things whilst it's out :grin: :laugh:
