Author Topic: Mk3 GTi problems??  (Read 3244 times)
Offline lmcmullen
Mk3 GTi problems??
« on: 23 July 2003, 09:51 »
Hi
Im looking to buy a mk3 GTi.
I dont want to waste my money so what should  I be looking out for on a 1996 P plate (around 60000 miles) which will indicate that there are problems with the car?
Also, has anyone had any problems with the catalytic converter on their mk3 GTi???
Cheers, Lee.
Offline Justins145bhpMK1
Re:Mk3 GTi problems??
« Reply #1 on: 23 July 2003, 11:04 »
Bear in mind they should have a cambelt at 6ok, check history if it has it. Other than that they are rock solid.
Offline Pimpster
« Reply #2 on: 23 July 2003, 11:05 »
Make sure all the electrics are in working order.
Also make sure its not rough running - if so could be throttle valve control.
No personal problems with the CAT. Have you heard they are an issue?
Make sure the lights behind the heater controls are working (sometimes can be very dim or not working at all).
Offline vr6mk2
« Reply #3 on: 23 July 2003, 11:26 »
at 60 000 miles the engine and mechanicals should be almost as good as new if the car has been treated with care. my mk3 had a non functioning electric window and the central locking pump was humming badly so check those.
