Author Topic: Gearbox?  (Read 1220 times)
Offline Dan84
Gearbox?
« on: 28 October 2009, 01:36 »
Hi all. Thought I would try asking this question as I've searched for an answer but can't seem to find one.
I have a mk2 with a 1.8 KR engine in it. Was wondering if they have the 020 gearbox attached? If so I have a nice whine coming from the gearbox are when I'm driving (I can only hear it when i'm driving down narrow streets and it echos off other cars). I looked to drain the gearbox oil and do a replacement but I can't find any info on doing this and the haynes manual is not very forthcoming. As far as I can tell there is a torx bolt underneath that looks like a drain off for the gearbox oil but when i removed this nothing came out, just a little trickle? I then undid the 17mm filler plug on the side and topped it up and it trickled out of the filler hole after a while, is this right? Just unsure of how much to put in as I'm sure it should be more than the 1/2 litre I put in there yet nothing came out when I undid the torx bolt underneath in the middle! Anyone able to point me in the right direction?
Re: Gearbox?
« Reply #1 on: 28 October 2009, 08:09 »
yeah its the 020 box, clicky for everythingyou could possibly want to know:
http://www.brokevw.com/
just fyi if you get a new one the 16v box has a larger input shaft, so needs a different clutch kit.  I'd get one from http://www.vwspares.co.uk
Offline Andy!
  • VR6
Re: Gearbox?
« Reply #2 on: 28 October 2009, 09:46 »
The Haynes manual lists the amount of oil needed. Be sure and get it right as it's no fun when gears start disintegrating.
Offline Dan84
Re: Gearbox?
« Reply #3 on: 28 October 2009, 14:44 »
Thanks guys, very helpful!
