Author Topic: cv joint  (Read 1632 times)
Offline JamesBaby
Re: cv joint
« Reply #10 on: 29 October 2009, 13:00 »
I did it with help of a mate. From what I recall it wasn't too bad.I did the brakes at the same time you see too.
Jack up the side so it's really high. I.e the wheel hangs down as low as possible. This aids getting the joint out of the hub.
Undo the hub.
Remove wishbone bolts and undo ball joint
Remove hub
Get mate to hold the drive shaft in, and prevent it coming out of the inner end.
Tap the CV joint off.
Refit
Spend week getting grease out of fingers.   :smiley:
