Author Topic: Day Three  (Read 861 times)
Offline Dan84
Day Three
« on: 27 October 2009, 01:31 »
I've now finished day three, serviced the car today with fresh new oil filter and plugs, checked the resistance on the leads so they're still good. Attempted to fit the backbox on properly but still blows slightly! Tomorrow I shall be tackling the gear box oil, speedo cable and instrument lights and the wiring issue with the lights/heater/wiper relays... I had to take the missus' 106 to the motor factors as the gti is so low it wont go up their drop kerb. Also after getting in tonight the central locking has given up again...
I am guessing that if the speedo isn't working that will affect the mpg/average speed readouts on the MFA?
Wish me luck!
Offline OakeyDoak16v
Re: Day Three
« Reply #1 on: 27 October 2009, 01:47 »
1. Whats wrong with the back box fittment?
2. Why are you changing the gear box oil?
3. What's wrong with the instrument panel that needs sorting?
Baz. :smiley:
Offline tony_ack
Re: Day Three
« Reply #2 on: 27 October 2009, 15:12 »
Yep. MPG is distance travelled per gallon of fuel. Distance travelled is derived from the speed (multiplied by time spent driving). The speed reading comes from the speed sensor on the speedo, which in turn comes from the cable connected to the gearbox.
If your speedo cable is bust, then the speedo won't work, and neither will the MPG, average speed or distance travelled.
The fuel usage reading comes from a vacuum sensor on the back of the speedo, which is connected via a vacuum pipe to the fuel inlet.
Getting to the back of the clocks is fiddly, but if you follow the guide on here, it's not too bad. Due to various clocks issues, I've had mine out 3 or 4 times, and can now get them out in about 20 minutes. Make sure you remember which screws go where, as there are at least three different types. And whatever you do, make sure you test the clocks fully before you put the dash back together...
1992 VW Golf MK2 GTI
1995 VW Corrado VR6
