Author Topic: Exhaust rattles - MOT fail?  (Read 2296 times)
Offline d4w50n
« on: 25 October 2009, 21:37 »
I had a friend adjust the handbrake on my car, he's a brake specialist. To do it, he removed the exhaust heatshield, and didn't bother to replace it.
Since then my exhaust rattles a little (not loads but audibly noticeable) on idle and a little more when the car is under load.
I'm not too bothered about it, when the windows are up it's hardly noticeable.
But the MOT is due in a couple of months, will it fail if the exhaust rattles, and is there any problem in not having the heat shield on there?
gtigolfthree
Re: Exhaust rattles - MOT fail?
« Reply #1 on: 25 October 2009, 22:26 »
rattle should be ok as long as exhaust is secure an not leaking, may fail on the heat shield for safety reasons.
Offline gazpowells
« Reply #2 on: 30 October 2009, 20:19 »
you should be ok come MOT time mate  :smiley:
« Reply #3 on: 01 November 2009, 00:05 »
I would try and refit the heat shield.  :smiley:
Offline Len
« Reply #4 on: 03 November 2009, 11:04 »
Depends which heatshield.
If it was the one under the CAT then do not bother refitting!
www.sas.org.uk
www.the-ace.org.uk
