Author Topic: coil issue? Right part?  (Read 1231 times)
Offline doely85
« on: 25 October 2009, 09:35 »
other night when it was raining went for a drive and car was cutting out and missfiring, so from what i have read in the common faults section i assume my coil pack has given up? is this the one i need:-
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf_2.0_1996/p/Car-Parts/Electrical-and-Lighting/Ignition/Ignition-Coils/?413440471&1&66ce934a7f9c99c15b54591067894cb0f6c906a2
Could it be anything else?
Thanks very much  :grin:
Offline justalex81
Re: coil issue? Right part?
« Reply #1 on: 25 October 2009, 09:53 »
water/moisture in the dizzy cap?
gtigolfthree
« Reply #2 on: 25 October 2009, 10:17 »
Yes give everything a good spray with a good moisture repelent or even wd40, cheaper option to try first.
Offline doely85
« Reply #3 on: 02 November 2009, 17:34 »
i sprayed coil and dizzy cap with wd40 and all seems well now cheers for the advice  :grin: i did check too see if coil was sparking but couldnt see anything so assume moisture was getting in the cap. Ta
Offline opel
« Reply #4 on: 02 November 2009, 18:37 »
coils usual pack up all together and they wont fire at all
Offline Mikester
  • Civic Type R
« Reply #5 on: 02 November 2009, 18:45 »
Or they will only fire once of twice and get weak as they break down. But wont be enough to start the car.
Offline doely85
« Reply #6 on: 04 November 2009, 16:42 »
cool must be the dizzy cap then, so if it starts playing up again will get a replacement. cheers
