Author Topic: roof trim white clips  (Read 1568 times)
Offline patty
« on: 24 October 2009, 12:54 »
one of my white clips that attach the gutter/roof trim to the car has snapped.
does anybody know the vw part no for these???or anywhere else that sells them????
im assumeing i will have to take the whole trim off,and replace all the clips with new ones??
is it hard /easy to do,i did use the search button and found a write up on a mk2 ,but nothing on a mk3...dont know weather they are the same trims?????
cheers in advance
pat.
1996 black 5 dr 2.0 gti 16v
Re: roof trim white clips
« Reply #1 on: 24 October 2009, 20:58 »
Will be VW only as a guess, should not be that expensive.
Offline Walkerboy
« Reply #2 on: 27 October 2009, 15:21 »
go to a windscreen company dude,beg and they should let you have a couple :smiley:
Offline Len
« Reply #3 on: 27 October 2009, 15:27 »
No More Nails?
www.sas.org.uk
www.the-ace.org.uk
Offline justalex81
« Reply #4 on: 27 October 2009, 21:09 »
grip fill and some 2 be 4  :grin:
Offline bored_Welsh_lad
« Reply #5 on: 28 October 2009, 08:17 »
just got to vw mun
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Offline Walkerboy
« Reply #6 on: 29 October 2009, 17:24 »
i'll try and find some over the weekend,sure we've got loads.will send you some
Offline patty
« Reply #7 on: 29 October 2009, 22:22 »
cheers fella !!!!!!!!!
pat
Offline Walkerboy
« Reply #8 on: 30 October 2009, 17:04 »
no worries.will pm you for your address when had a look 2moz dude
Offline Walkerboy
« Reply #9 on: 30 October 2009, 17:09 »
white clips look like christmas crackers dude?????fit onto the body of the car??????
found 6,well there for the caddy,but there the same,just need to push the trims down harder and there snap in.
pm me your address and i'll send them to you
