Author Topic: Hall sender part no. ?  (Read 952 times)
Offline skcollob_ho
« on: 23 October 2009, 14:20 »
Does anyone know the part no. for a hall sender for an ABF, please?
A totalitarian regime, crushes all autonomy in it's drive to seize the human soul.
Offline Horney
Re: Hall sender part no. ?
« Reply #1 on: 23 October 2009, 14:29 »
I think you need a complete replacement dizzy. I had this problem on my 2.0 16 Rado and just got a good used Dizzy instead and problem solved.
Nick
Offline skcollob_ho
« Reply #2 on: 23 October 2009, 14:42 »
Thanks for the reply Nick.
Do you know roughly how much this is going to cost me!?
I called my local dealers, and they quoted 89+VAT for it. I even checked that it was a seperate part, and they confirmed it was.
Offline Horney
« Reply #3 on: 23 October 2009, 15:01 »
You should be able to pick up a complete recon dizzy on eBay for less than that.
nick
Offline Paul86S2
« Reply #4 on: 23 October 2009, 23:34 »
You can change them but it is fiddly and complicated, you will need to drive a pin out which will require a punch a large hammer and a lot of force. You will probably damage something else whilst doing this. As Nick says you could probably get a recon one for less, or try your luck and buy secondhand.
How do you know your hall sender is faulty?
Paul
Offline skcollob_ho
« Reply #5 on: 30 October 2009, 16:07 »
Well, I replaced the ECU with a non-immob. earlier version, and the car now starts [albeit under full throttle] and runs for about 10mins then just cuts out! No chugging, just cuts out.
I called the auto electrician who advised me that my ECU was shot, and when I described the symptoms, he said it was the hall sender that needed replacing.
What is weird though, it that although I have fitted an ECU that doesnt have an immob. I still need to disable it before my ignition lights come on. This would mean that its actually an aftermarket immob. right?
God I'm crap at this sort of thing!
