Author Topic: 8v GTI - Rev limiter/counter problem  (Read 1171 times)
Offline Biz
« on: 21 October 2009, 23:05 »
Hi
Picked up my 8v GTI at the weekend and runs fine apart from it appears to hit the rev limiter at 5,500rpm and it appears to rev high on the rev counter.
Not up to speed on my mk3's yet so any help would be great, before I attack it with a hammer at the weekend!
Have been told might be distributor but not sure.
Dave
Offline Mikester
  • Civic Type R
Re: 8v GTI - Rev limiter/counter problem
« Reply #1 on: 21 October 2009, 23:17 »
If the timing is out very very slightly it puts a limiter in so that it cant do damage to itself.
So it may be the ecu doing this, although it brings in a limiter at 5000rpm normally.
But i reckon it could be timing related.
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 21 October 2009, 23:26 »
I guess you mean it idle's high and won't rev over 5500 which would suggest a timing issue (or worst case the car's in fault mode to protect itself and it will need a scan for that)
Offline Biz
« Reply #3 on: 21 October 2009, 23:41 »
cheers i'll have a look at the timing
Offline bored_Welsh_lad
« Reply #4 on: 22 October 2009, 14:09 »
might be worth reading this too..
http://www.golfgtiforum.co.uk/index.php?topic=128949.0
all the links in the thread have tonnes of useful info in them, including stuff like timing up an 8v
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
