Author Topic: power steering pump/ abs  (Read 1329 times)
Offline coggers79
« on: 21 October 2009, 08:51 »
anyone got a power steering pump for 96 16v in north east mine is leaking or is there a fix. also got problem abs light on and back brakes comong on just before fronts help please
Offline Len
Re: power steering pump/ abs
« Reply #1 on: 21 October 2009, 09:04 »
abs light is probably a sensor.
rear brakes is probably the bias.
put a post in the wanted section for the pump.
www.sas.org.uk
www.the-ace.org.uk
gtigolfthree
« Reply #2 on: 21 October 2009, 09:16 »
Or phone round the scrappies.
Offline coggers79
« Reply #3 on: 21 October 2009, 12:26 »
is there a bias on the 16v as i bought a compensator but my car dont have one
Offline Len
« Reply #4 on: 21 October 2009, 13:34 »
Sure mine has!
maybe your problem is a sticky caliper then?
www.sas.org.uk
www.the-ace.org.uk
Offline Paul86S2
« Reply #5 on: 21 October 2009, 13:59 »
No bias valve on the 16v. It's all run by the abs unit which may be why you have a problem.
I would suspect you have a speed sensor fault on one of the wheels.
Paul
Offline AudiA8Quattro
« Reply #6 on: 21 October 2009, 17:03 »
Paul
True, but only on later models.
I'm sure the early models, like the 8v and vr6 still have the valve. I think it changed about 1995?
If the abs system has shut down then there is a potential for the back brakes to lock, as Paul said, that model doesn't have the bias valve.
Put the car on VAG com, or test all the sensors for continuity, duff sensors usually won't give a reading at all.
