Author Topic: Reverse lights won't switch off!!!  (Read 1085 times)
Offline sharpse74
« on: 20 October 2009, 19:59 »
Hi all i'm new to this forum, just purchased a mk2 16v '89 (from ebay sorry!!).  I have reasonably big plans for the car but dont want to go ballistic, after degreasing and cleaning the engine bay i found the reversing plug not connected.  After connecting the plug i found the lights to work (hooray) but will not switch off??  has anyone had the same issue with their mk2 any advice would be much appreciated cheers...
Offline johnson6672
Re: Reverse lights won't switch off!!!
« Reply #1 on: 20 October 2009, 20:18 »
Sounds like a fault in the switch do they go out with it unlugged? if so take the swictc out, plug it in then give it then try applying the swich by hand or moving it to see if the lights go out, its either a new switch or it just needs cleaning up and freeing off, but my first port of call would be to remove the switch and see what happens then.
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
« Reply #2 on: 22 October 2009, 15:20 »
The fact it was unplugged suggests to me that the switch is faulty.
Offline dragonfly
« Reply #3 on: 22 October 2009, 17:11 »
Relatively cheap fix - new switches are available from Euro Carparts and GSF.  Deep 22mm socket and the switch is removed.
Offline Reasty
  • Alpine white valver.
« Reply #4 on: 22 October 2009, 21:33 »
Even cheaper fix: take the switch out of the gearbox and spray it with wd40 then push the ballbearing in and out a few times wiping any gunge that comes out off,then pop it back in and my bet is it works again!  :wink:
Offline sharpse74
« Reply #5 on: 25 October 2009, 21:30 »
Thanks for the advice i've ordered a new switch from VAG (under a tenner) and will fit shortly.
