Author Topic: Alternator belt won't stay on  (Read 1135 times)
Offline doopydug
« on: 26 September 2004, 23:16 »
Well, I seem to be having trouble holding on to alternator belts. On my 3rd one now - garage says that the pulleys seem to be mis-aligned but I can't see it.
I notice that the adjustment bolt on the alternator isn't the ratchet type - just a normal bolt. Could this be allowing slippage?
Does it have to be the proper bolt?
90 16V MKII with PAS
Offline richandhazel
Re: Alternator belt won't stay on
« Reply #1 on: 26 September 2004, 23:39 »
No, I doubt it is the bolt causing the problem. It is quite common for those teeth to get worn and on my cab I have replaced the toothed bolt for a normal one. As long as you tension the belt ok the replacement bolt will do the same job.
