Author Topic: mk3 mfa dials into a se  (Read 1190 times)
Offline JamieS
« on: 19 October 2009, 23:31 »
Is it possible to fit the mfa dials off say a gti colour concept into a se with the stalk aswell and what wiring and sensors would be needed to make it all work?
Thanks
Jamie
Re: mk3 mfa dials into a se
« Reply #1 on: 20 October 2009, 10:57 »
clocks, stalk and the loom from the stalk to fusebox to get basic mfa functionality working,. then you need an oil and outside temp sensor, then wire these up to plug F on the fusebox, see the fusebox faq (its in the mk2 maintenance + info section for some reason!)
Offline JamieS
« Reply #2 on: 20 October 2009, 20:45 »
Main thing I wanted the mfa for was mpg.. try and hone my driving to minimise fuel usage  :wink:
