Author Topic: Golf mk3 GTI 8v front discs  (Read 2892 times)
Offline AntMk3GTi
« on: 19 October 2009, 15:00 »
Hi
Ive got a P reg (1996) 8v GTI and Im thinking of changing my front discs soon so ive checked the internet for a new set, but my Haynes manual says the dimensions are; Diameter - 280mm and Thickness - 22mm. On the internet is only gives these dimensions for models up to '93!?
For my year it says i need diameter 288mm and thickness 25m?
Has anybody changed them recently and know what ones i need to get?
Offline Guy
Re: Golf mk3 GTI 8v front discs
« Reply #1 on: 19 October 2009, 15:02 »
go to GSF and get the brembo grooved discs and greenstuff pads... doesn't cost that much in comparison to 'normal' ones and the braking is significantly improved
Offline AntMk3GTi
« Reply #2 on: 19 October 2009, 15:03 »
Has much is that all together mate?
Offline axewielder
  • 95 dragon 8v
« Reply #3 on: 19 October 2009, 15:11 »
mine is a 95 with ADY engine + has 280 discs, yours might be 288 though
whatever said 280 was only upto 93 is wrong
could give vw/decent parts place a call+ quote your reg no to get definative answer
Offline AntMk3GTi
« Reply #4 on: 19 October 2009, 15:14 »
Yeh thats prob the best idea ill just give VW a ring.  Mines an AGG engine if that makes any difference.
Offline axewielder
  • 95 dragon 8v
« Reply #5 on: 19 October 2009, 15:23 »
i think most aggs had 288s but best to make sure
« Reply #6 on: 19 October 2009, 15:46 »
99% sure yours will be 288.
gtigolfthree
« Reply #7 on: 19 October 2009, 15:47 »
Mine is sep 95 with agg and 280 discs, measure them if your not sure.
Offline Ess_Three
« Reply #8 on: 19 October 2009, 16:06 »
A glance at the callipers will tell you...
If they have a sort of silver spring clip (like a formed thick wire) on the outside of the calliper, visible, they are the 288mm/312mm type ATE callipers.
If not, they are 280s.
As for Greenstuff pads...I managed to get mine to de-laminate - the pad came off the backing.
They worked well enough, and didn't produce much dust..but I'd still not fit them again.
Freodo DS2500s work especially well.
..but gaining motorcycles.
gtigolfthree
« Reply #9 on: 19 October 2009, 16:19 »
I use Mintex, good performance and value for money.
