Author Topic: Cambelts gone. need help ?  (Read 4327 times)
gtigolfthree
Re: Cambelts gone. need help ?
« Reply #30 on: 04 November 2009, 12:18 »
Sorry that's the 2.0L You will need a haynes manual.
« Reply #31 on: 04 November 2009, 12:31 »
Nearly the same engine, will not be much different to do.
Offline Matty-MK3
  • Automatic boats FTW.
« Reply #32 on: 04 November 2009, 18:50 »
+1.
Golf MK3 1.8 auto and I didn't pay a grand for the "priveledge" :grin:, auto windows all round and a AC. Oh and I've got a luggage net you pricks!
Does that make my willy look bigger?
Oh yeah it's called Helda or something....
Offline harlemex
« Reply #33 on: 05 November 2009, 20:36 »
you dont need a new tensioner at this point. If you just want to check the engines okay just put a cambelt on, that way its only cost you about a tenner. If engine is okay, then buy a tensioner.
Offline Amzy-Bear
« Reply #34 on: 19 November 2009, 11:59 »
well i cant do a cambelt myself, but ive been quoted £130 to fit a new cambelt, timing belt and tensioner. thats including the parts !! is that a good quote ? i didnt think it was too bad.
:D
« Reply #35 on: 19 November 2009, 12:36 »
Yes good price.
Offline Len
« Reply #36 on: 19 November 2009, 13:27 »
Same as I was quoted
www.sas.org.uk
www.the-ace.org.uk
Offline harlemex
« Reply #37 on: 19 November 2009, 14:29 »
parts=30 quid. labour 1 hour=100 pounds. Rip off.
Offline daytona
« Reply #38 on: 19 November 2009, 17:24 »
As said,just get the parts for now,but just put the belt on, take the plugs out and move it by hand,do not start and run it cos if it is damaged it could jam and snap the new belt anyway,so by hand to be safe.If all moves ok,replace the parts,but that does not indicate everythings fine.At the end of the day it is better all round to just whip the head off,should take no more than an hour if taken ye time.Dont for get the inlet and outlet will need removing.A new head gasket and bolts for futures sake will help anyway.Unless you had gasket probs u dont need a head skim,and whilst its off u might as well give it a de-coke if alls ok.Buy a haynes manual cos u will feel great afterwards that u did it yourself,and save a hell of a lot of money.Even if the head needs replacing,look for a second hand one IN GOOD CONDITION,and learn to do the work yourself.Tbh,its how mechanics done it when they where learning,they have to read and do the prectical work themselves,so why not you??
if in doubt,rev the arse out of it
Offline evokid
« Reply #39 on: 22 November 2009, 09:26 »
id deffo go with belt and time it up.....Very resilant engines...My crankshaft bolt sheard, pulley bounced around engine then in road whilst doing 80 mph!!! Timing belt came off, and was attempted to start by RAC!!!
But new belt/pulley and bolt and now back running fine for me ...2.0   8v engine 2E engine  (I did have a few other issues but not related to the initial incident)
But worth a try..... :smiley:
