Author Topic: Cambelts gone. need help ?  (Read 4324 times)
Offline Amzy-Bear
Re: Cambelts gone. need help ?
« Reply #20 on: 02 November 2009, 19:15 »
im a mechanic, Its highly likely that there would be some valve damage. You mite beable to buy a new head off ebay complete with valves and cams for £200 ish. u have to make sure u get the right one to the engine code. Valves cost between £5-£10 a valve. Then would need bedding in with grinding paste!!! Also if your taking head off then i would advise to get the head skimmed. thats cost bout £50. Head set bout £100 with head bolts. I reckon it would cost u bout £500 ish to have the latter done with labour.
Cylinder leak test will tell u bout any bent valves
Okay well thanks for that, deffo not spending that much on a head, went to a local VW Spares place today who quoted me £75 + Vat which i thought was a little steep. But just got paid the other day and looking to get her on the road.dont wanna spend more than £250 to get her back on the road.
:D
Offline Amzy-Bear
« Reply #21 on: 02 November 2009, 19:18 »
Head bolts are about a quid each or so. Head gasket set, about 30. 2nd hand head I would not spend much more than 50-60. The real cost comes if there is piston damage. £500 is far too much to spend.
yh deffo, thats the sort of money my matey reckoned aswell. i think il change the belts and tensioners and see what happens, then if its not good, get a head off ebay or here or somewhere. cheers for your comments mate,v helpful  :smiley:
:D
Offline Matty-MK3
  • Automatic boats FTW.
« Reply #22 on: 02 November 2009, 19:30 »
Seriously. Spend £30 on a cambelt kit, fit it, it's easy.
Try to start the car. We've had a GTi on here recently which snapped it's cambelt, new belt and it ran!
Do it, you need a cambelt anyway.
Golf MK3 1.8 auto and I didn't pay a grand for the "priveledge" :grin:, auto windows all round and a AC. Oh and I've got a luggage net you pricks!
Does that make my willy look bigger?
Oh yeah it's called Helda or something....
Offline Amzy-Bear
« Reply #23 on: 02 November 2009, 19:33 »
yea i went into GSF today and got quoted £37 ex vat for a kit,
with cambelt, timing belt and tensioners. i think lol
:D
Offline Matty-MK3
« Reply #24 on: 02 November 2009, 19:44 »
Worth it or re-read DPB's post on the first page! :afro:
gtigolfthree
« Reply #25 on: 02 November 2009, 21:22 »
I have heard a lot of storys of people "getting away" with a snapped cam belt and no damage. Even sugestions that this is a "clearance engine" i.e the valves can't hit the pistons if the belt snaps, so its surely worth a go replacing the belt and post the result and mabye someone  can confirm that or if the valves can and do hit the pistons when the belt snaps.
« Last Edit: 03 November 2009, 21:10 by gtigolfthree »
Offline Amzy-Bear
« Reply #26 on: 03 November 2009, 20:08 »
Yeh will do, picking up a belt tomorrow. its just getting someone to pop it on, ill put a post up once its on.
:D
Offline Matty-MK3
« Reply #27 on: 03 November 2009, 23:35 »
You could try yourself.
Once you understand the marks, it is very easy.
I think even Shady could do it! :shocked:
gtigolfthree
Offline Amzy-Bear
« Reply #29 on: 04 November 2009, 11:06 »
is that the same as mine, loooks a little different.
mines a 1.6 cl, also my cambelt is over on the driverside lol
:D
