Author Topic: platic trim on a mk3..  (Read 2038 times)
Offline luke
  • When in doubt, whip it out!
« on: 19 October 2009, 12:22 »
will the plastic exterior plastic (on doors, arches, and bumpers) bits just pull off, is it glue or will i need filler?
1985 mk2 gti type 19 8v
2018 t roc sel 1.6tdi
Offline Deano2711
  • 1992 VR6
Re: platic trim on a mk3..
« Reply #1 on: 19 October 2009, 12:24 »
From the many threads I have read on here regarding de arching the GTi's you will need to heat the glue under the plastic then remove plastic parts and polish/cut out the marks left by the glue.     Hope this helps     Deano
« Reply #2 on: 19 October 2009, 12:25 »
Arches are pop riveted, door trims clip on and you will need a CL set to replace them.
Offline VR6-Joe
« Reply #3 on: 19 October 2009, 13:16 »
+1 - Rivets will need to be drilled out to remove the arches, and the door trims are held on by clips, but when de-arching a Mk3 you need the CL side trims from front to back.
Although if you have an SE like your sig suggests, for the love of god leave them on, they look so much better!
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline luke
« Reply #4 on: 19 October 2009, 17:08 »
i don't really want plastic on it, unless there is somehow i can get them to green..
forgot to say im goin for the 'euro' look, all smooth and that..
« Reply #5 on: 19 October 2009, 17:18 »
Underneath the door trims are holes which will need welding up and plating over, will look crap and very plain without them.
Offline luke
« Reply #6 on: 19 October 2009, 17:34 »
i know what i will do, when i get it on friday, i will take a few pics of it and have a vote..
Offline ace
« Reply #7 on: 19 October 2009, 18:18 »
get the trims from a cl and get it colour coded. also from your sig, u will need to get cl bumpers as well to have full colour coded.
Offline VR6-Joe
« Reply #8 on: 19 October 2009, 18:20 »
My old SE
Offline boneybradley
  • Back in a Mk3...
« Reply #9 on: 19 October 2009, 19:24 »
and if you remove the arches, door trims etc your quite likely to find rust or knackered paint!! so remove them if you don't mind some paint time  :wink:
