Author Topic: Delicate starting procedure  (Read 4119 times)
Offline Harooshum
« on: 19 October 2009, 12:04 »
Hreg mk2 16v 174k miles off the road and hasnt been started in about 3 years.  I sought some advice on bringing her back to life, just wanted to run it over in here.
1- remove spark plugs and pour a little engine oil down those gaps into the cylinders.
2- remove fuel pump fuse
3- engage starter for 5 secs, then switch off.  Repeat several times.
4- put fuel pump fuse back in, and replace the spark plugs with new ones.
5- start as normal without revving, just idle for 5-10 mins.
6- change engine oil and filter
Im concerned about starting the engine after such an amount of time, as the upper parts of the engine may not be lubricated.  Would it be best to drain the oil and remove/clean the sump for all the crap buiding up down there?
Thanks.  h.
Offline bodga
  • F reg GTI 16v
Re: Delicate starting procedure
« Reply #1 on: 19 October 2009, 12:50 »
M 16valver had deen standing aout 10 years according to the last owner. Ihad to replace both fuel pumps before she fired up and then i had to give the air meter a good clean up.The needle was stuck so i wrapped it in a rag and pulled it out with some pliers. cleaned it with petrol and she runs sweet now. change the cam belt asap. mine was ready to snap! :grin: I enjoyed getting it running thou. both pumps i found off ebay second hand. good luck :smiley:
Offline Ben Lessani
« Reply #2 on: 19 October 2009, 13:41 »
@Harooshum, I'd be more inclined to change the oil first, then do as you said.
Spinning the starter with no sparkies will lubricate the bores and get the oil flowing, which is exactly what you want.
Offline danny_p
« Reply #3 on: 19 October 2009, 14:49 »
id chuck some thin oil down the plug holes and leave it oer night first.
spin it over with plugs out fo rabout 30 secs.
then check the cam belt and make sure it's getting fresh fuel
all the VW's have gone bar 1.
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #4 on: 19 October 2009, 18:07 »
What I was about to say. Spray oil down the plug holes to give everything a good coating and leave for a few hours. Then spin it over without plugs in, in case of hydraulic lock and to get things moving.
When you go for the start, expect clouds of smoke from the exhaust. This will burn off after a few seconds, hopefully.
Offline Harooshum
« Reply #5 on: 25 October 2009, 11:48 »
Not sure what you mean.  I used to take apart the entire air filter housing along with all the parts to and including the throttle, and give it a good clean with carburettor cleaner along with the isv valve as part of my regular servicing if thats what u mean - stuck needle???
Thanks for all your replies, im about to start doing this on this lovely sunday morning but I cant find my spark plug tool - need to go gsf!  For as long as i've owned mk2's i've always used vw's silver synth oil but another mk2 owner tells me there is a better one.  Is there?
My list:
£20  cambelt  -  or  -  £35 cambelt kit inc tensioner
£18  bosch sparks super 4
£10  k&n oil filter
£10  fuel filter
£80  front brake discs 239mm (already have new greenstuff pads)
£8   gear linkage bush kit
£50  pair of fromt elec window motors
Total = £196
Found all these on ebay, can anyone advise which is best to get from gsf?  I know their parts are not always good for mk2's.  thanks.
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #6 on: 25 October 2009, 13:05 »
All of the above, but, I wouldn't start engine until the cambelt was at least inspected, or replaced
Fuel is likely to be an issue, it goes off after a couple of years, this could be an issue if the car doesn't run properly, and your thinking its something else at fault
Thom
Offline Harooshum
« Reply #7 on: 25 October 2009, 18:02 »
Thanks, i wish I could get that far...
Removed sparks 1 and 4, spark 2 twists easily but keeps twisting and wont come out (plug's threads?), and the spark 3 hole wont allow the plug tool to enter as it gets stuck half-way down the shaft.  I twisted, and eventually got it all the way in there and the spark twists easily, like spark 2, but I cant tell if the tool is bringing the plug with it up, as the tool gets stuck half-way up the shaft and detaches from my ratchet!!  I tell u what, I'm getting very pissed with this car and probably better off getting a new engine!!
2.0 tsi - yes please!
I cant find any info on spark plugs getting stuck, surely this has happened before?
« Reply #8 on: 26 October 2009, 09:59 »
sounds liek you'll have to have the rocker cover off to get your tool out. common issue on these, some of the aftermarket gaskets sqush out into the plug holes a bit too much. I have also learnt this the hard way, so whenever I do sparkies I tape the plug tool to my ratchet!
it does sound like your plugs are threaded, but it can be fixed with the head in situ.  someone I know had the same problem on their ABF engine, and got it fixed with a helicoil type insert. was done with head on, there is a risk of metal shavings getting into the piston but if you give it a good hoover out it should be ok. worst case and engine blows up, 2.0 16v time ;)
http://www.clubgti.co.uk/forum/showthread.php?t=201407
Offline Harooshum
« Reply #9 on: 26 October 2009, 11:47 »
rocker cover off?  That'll be the inlet manifold off too!  Yes it certainly feels like the gasket has mushed its way into the spark plug holes, but only on plug 3 and not all 4!!!   Obviously i will need a new rocker gasket kit, and maybe for the inlet manifold (because its 2 parts) aswell.
Can I have some advice on the replacement gaskets I need for all this please.  Thanks.  h.
