Author Topic: 1.3 is dying  (Read 958 times)
Offline mwep201081
1.3 is dying
« on: 18 October 2009, 21:54 »
With the engine sitting at about 1900RPM in 4th the revs intermittently drop by about 500RPM very quickly before shooting back up to 1900. It does this twice in about 10 seconds then drives fine for 15-20 mins then does it again. I've changed the plugs, rotor arm, cap and points, but not sure if the problem is electrical of mechanical to be honest.
My hunch is that it may be over fuelling so I'm going to check the condition of the plugs tomorrow.
I think I'll check the compression of the cylinders while I'm at it.
If any one else could shed some light on what they think the problem could be I'd be grateful!!
Offline weazgti
Re: 1.3 is dying
« Reply #1 on: 19 October 2009, 20:26 »
carb icing and and choke problems my old one had.
Is the warm air feed still there?
Offline mwep201081
Re: 1.3 is dying
« Reply #2 on: 19 October 2009, 21:03 »
I've got the direct replacement Weber carb with the manual choke and the warm air feed is in place. I've not had a chance to do anything today (been struck down by a virus)
