Author Topic: Glovebox Light  (Read 3960 times)
nick_thomas
Glovebox Light
« on: 18 October 2009, 21:47 »
I've had the golf a year and only discovered that there is one.
Upon closer inspection it didn't work, the bulb was fine, fiddled it a bit and it sprung into life.
Right, it's on whenever the ignition is on, regardless of whether the glove box is open or not, I add this is the upper glovebox (8v GTI).
My only worry is the bulb getting nice and hot because it's on whenever the engine/ignition is on, there doesn't seem to be a switch anywhere.
This right.
Thanks in advance.
gtigolfthree
Re: Glovebox Light
« Reply #1 on: 18 October 2009, 21:59 »
Is it not linked to your interior lights?
Offline VR6-Joe
Re: Glovebox Light
« Reply #2 on: 18 October 2009, 22:33 »
It's supposed to be like that. I've had 4 Mk3's and the only one that was different was the VR6 because it had a passenger airbag and lower glovebox
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline Paul86S2
Re: Glovebox Light
« Reply #3 on: 18 October 2009, 22:50 »
The switch on my 16v is part of the light bulb housing and is worked by the curved arm on the glovebox lid that holds it in the open position.
I would doubt that any others are differant. You will probably find either the spring in the switch has gone or part of the plastic has broken off.
Pop the light out and have a look.
Paul
Re: Glovebox Light
« Reply #4 on: 19 October 2009, 09:11 »
Remove the bulb.
nick_thomas
Re: Glovebox Light
« Reply #5 on: 19 October 2009, 12:42 »
Cheers, I'll check Vag-cat tonight to see if anything has snapped off, but the arm on the door of the box certainly doesn't touch the light assy in any way.
Would anyone be kind enough to take a picture of theirs so I may check?
Regards
Offline VR6-Joe
Re: Glovebox Light
« Reply #6 on: 19 October 2009, 13:13 »
Paul
Seems a coincidence that all 3 of my base model Mk3's have been like it then? If you pop off one of the blanks next to the heated rear screen switch you can normally see the glovebox light from there, or on my 1.4 Ryder the glovebox handle was non existant so you could see it through there also
adamrob69
Re: Glovebox Light
« Reply #7 on: 19 October 2009, 19:10 »
more then likely that the light mechanism had broke, and someone had made it so it worked like that.
Both my mk3s 1.4 base model and 2.0l  had the mechanical mechanism when when you open the glovebox it would light up, when you close it the contact will become open and the light goes out. on my 1.4 i broke the mechanism (which is spring driven) and nearly took me 3 weeks to work out how it worked (without the abilty to look at a working one) so i could put the spring back in correctly!
i would suggest the your mechanism isnt quite put together right, so it holds all the plastic together, but it makes permanent contact hence the bulb on all the time. Easy option is get one from scrappy or take bulb out, or see if you can get a pic of what the mechanism should go together like and try to fix it.
