Author Topic: Metal cracked around clutch cable  (Read 4669 times)
Offline Madone_si
  • Seattle WA, USA and Middlesex, UK
« on: 26 September 2004, 13:36 »
I don't believe it - bloody car.......  >:(
I have a LARGE crack around the clutch cable mount that is at the back of the engine bay so clutch doesn't work at all now, it moves freely.....
Does any one know the best way of fixing this?
Any help is appreicated
Old Skool Mk1 Golf Gli (82), Mk1 US Cab 85 and 83
SOLD - BLACK SOY 92
Offline AdamB
  • The Perfect Storm
Re: Metal cracked around clutch cable
« Reply #1 on: 26 September 2004, 13:59 »
This is a common fault, and there are kits available to fix it. the are just a piece of metal, cut and shaped to fit in the bulkhead, over the weak point.
Have a search on some of the VW sites for it.
I don't own this anymore - I just can't be arsed to change the picture
Offline Madone_si
« Reply #2 on: 26 September 2004, 14:03 »
thanks Adam, I thought that might be the case.
SOLD - BLACK SOY 92
Offline Madone_si
« Reply #3 on: 26 September 2004, 16:41 »
For anyone else that may require this kit.
Bulkhead repair plate"  ?7.60+VAT part no.71717B from - http://www.gsfcarparts.com
SOLD - BLACK SOY 92
Offline richandhazel
« Reply #4 on: 26 September 2004, 17:21 »
I had to do my cab just over a year ago. As Adam says, its a very common failure.............I've fitted the kit to three mk1's myself!
Offline gibby
« Reply #5 on: 27 September 2004, 08:23 »
Yup mine went last year too  :(
......now officially dubless.
Offline Madone_si
« Reply #6 on: 27 September 2004, 11:05 »
Will I need a welder to put the kit onto the car?
SOLD - BLACK SOY 92
« Reply #7 on: 27 September 2004, 11:27 »
It can be welded in but to be honest when I did mine I used some high strength aircraft sealant from work............worked a treat and overpaintable. If I remember correctly the kit includes some self adhesive pads.
« Last Edit: 27 September 2004, 13:03 by richandhazel »
Offline Madone_si
« Reply #8 on: 27 September 2004, 11:36 »
ok. Where do you work then Rich?
SOLD - BLACK SOY 92
« Reply #9 on: 27 September 2004, 13:03 »
Heathrow.........aircraft engineer for bmi
