Author Topic: Forge Acuator Replacing My Crappy Weak One Soon.......  (Read 4704 times)
Offline Grand Master Patch
Hey Nick,have you ever done one of these on a baby k03s before?
Would the map need tweaking to suit,or is it a case of trial and error :grin:
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Re: Forge Acuator Replacing My Crappy Weak One Soon.......
« Reply #1 on: 18 October 2009, 10:26 »
Hello,
Fitted 100s of Acuators & external wastes gates, but never a Forge one to a KO3s.. :smiley:
We will get it back on the dyno and do some external logging and map tweaks to make sure your getting the best from your car.
I am looking forward to getting it running spot on and boostinh right.
Nick
 01455 617233
« Reply #2 on: 18 October 2009, 10:36 »
It runs pretty damm good now,just missing the extra few torques lower down.
Am i right in thinking that these uprated actuators allow the boost to stay high right up to redline,or would that be pushing the turbo beyond it's capabilities?
Offline RTechUK
« Reply #3 on: 18 October 2009, 16:19 »
Setup wrong  and over tight they can strain the turbo, we need to aim for a setup the same as the oem setup.  We will use the tool which we tested the Forge 007p with to get it adjusted right.
Nick
 01455 617233
Offline topher
  • Administrator
  • fully functioning
« Reply #4 on: 18 October 2009, 20:34 »
just been told it's a turbo-off job to swap the actuator :lipsrsealed:
« Reply #5 on: 18 October 2009, 21:48 »
Turbo Off? Guess you lot are going to be busy :grin: Does the price you quoted still stand?
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #6 on: 18 October 2009, 22:58 »
thats what i thought and thats why i hope my actuators fine  :grin:
2000 Mkiv GTi 1.8T AGU
« Reply #7 on: 19 October 2009, 21:44 »
After a conversation with Nick,it might be possible without removing the turbo after all.Charge pipe off and 3 bolts holing the turbo to manifold might just give enough room,fingers crossed......
  • "1.8T AGU"
« Reply #8 on: 19 October 2009, 21:55 »
hopefully  :grin: your the guinea pig  :wink: if you get on okay i'l have a think on this one then :afro:
« Reply #9 on: 19 October 2009, 22:13 »
If it's a full turbo off Job i think i'll wait another 3K and and do it then(new gaskets/oil/water/manifold bolts etc....)
Nicks going to try adjusting my std actuator first,if that gives good results it saves me money and his time.
I need to speak to Nick more on the day,but from what i can see well over 25psi can be had....
