Author Topic: Odd rear wiper fault  (Read 1362 times)
Offline local_boy
« on: 16 October 2009, 20:56 »
ok so the rear wiper on my 97 8v gti hasnt worked since i got it, and its now its turn on the list of little things to sort (before it needs more welding...) Just wondered if anyone has a wiring diagram for the rear wiper circuit, and knows what the 3 pins are on the plug (center is earth). Got odd readings on the outer two, one is around 2.5v other about 3.7v. Switch seems to be working as the 3.7v drops to zero when moved. Any ideas?
Offline Matty-MK3
  • Automatic boats FTW.
Re: Odd rear wiper fault
« Reply #1 on: 17 October 2009, 22:46 »
Poor/corroded connection/switch somewhere.
Golf MK3 1.8 auto and I didn't pay a grand for the "priveledge" :grin:, auto windows all round and a AC. Oh and I've got a luggage net you pricks!
Does that make my willy look bigger?
Oh yeah it's called Helda or something....
Offline Len
« Reply #2 on: 03 November 2009, 12:03 »
Check the wires where they go through the hatch grommet.
www.sas.org.uk
www.the-ace.org.uk
Offline local_boy
« Reply #3 on: 08 November 2009, 00:21 »
Checked through to where connectors are behind n/s/r light and there fine. Anyone know what relay controls the rear wiper?
Offline local_boy
« Reply #4 on: 11 January 2010, 23:51 »
Just a bump and question, should the stalk 'click' into the rear wipe position?
« Reply #5 on: 12 January 2010, 08:33 »
No from memory, the relay should click however.
Offline local_boy
« Reply #6 on: 06 March 2010, 19:59 »
Found it! internal short in fuse box not suppling voltage to relay. Now an external relay with its own supply!
