Author Topic: 020 rear gear box mount bolts in mk1 caddy  (Read 933 times)
Offline Tom21
« on: 16 October 2009, 16:39 »
As exspected im missing bolts doing my KR conversion in my mk1 caddy. I need the three bolts for the rear gear box mount but i'm unsure of the size? I think there 10mm thread and about 25mm long but dont want to mess up the thread on the gear box. cheers
Re: 020 rear gear box mount bolts in mk1 caddy
« Reply #1 on: 19 October 2009, 09:12 »
on a mk1 these holes have studs in. you could use bolts if you wanted, just make sure they're not too long that they bottom out, and not too short that there isnt enough meat on them. M10 is the thread. You'll probably need to run a tap down the holes as no doubt be full of crud by now
