Golf mk3
hardmonkeys
Temp light flashing but gauge works fine
Topic: Temp light flashing but gauge works fine (Read 850 times)
Tommyk
16 October 2009, 14:47 »
Hi, ive tried to search my problem without luck so here goes.....
the temp light starting coming on intermittantly on the dash an now flashes all the time when driving, but the gauge works fine and the cars drives fine...... any ideas??
Tommy.
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Re: Temp light flashing but gauge works fine
16 October 2009, 15:09 »
the temp light is also a low coolant level warning. if the coolant level is ok, disconnect the plug from the header tank and bridge the pins. if that stops the light flashing you need a new header tank.
if that doesn't fix it or you don't have a level sensor, it could be down to the temperature sensor
Tommyk
16 October 2009, 15:12 »
Many thanks. Tommy.
Golf mk3
hardmonkeys
