Author Topic: 2 aeirals?  (Read 1929 times)
Offline NickB91
2 aeirals?
« on: 15 October 2009, 12:39 »
I have a 1.6 CL but it has two aeirals on it the bee sting on the roof and an electric one on the bonnet, i want to get rid of the electric one but i can only find one wire going to the head unit, would i have to take the roof lining out to trace the wire back or is there an easier way? Also water leaks into my passenger footwell i've had to replace the fan motor already becasue it blew from having water leaking on it, if anyones had a similar problem could you let me know how you fixed it.
Cheers any help is much appreciated.
Offline VR6-Joe
Re: 2 aeirals?
« Reply #1 on: 15 October 2009, 12:55 »
The roof one has obviously been fitted at a later date..
I had a wing mounted aerial on my 1.6 CL when I bought it but I took the wheel arch lining out, cut the wire, then ripped the aerial off and put a grommet in the hole so I could fit a roof aerial.
Are you sure your wing mounted aerial is electric? As mine wasn't...
As for the water leak, do you have a sunroof? If so, check the drainage tubes located on the A pillar when the door is opened.
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Re: 2 aeirals?
« Reply #2 on: 15 October 2009, 13:08 »
Welcome to the site.
Offline Len
Re: 2 aeirals?
« Reply #3 on: 15 October 2009, 13:16 »
maybe the roof aerial was for show only?
As for the leak also check the plastic scuttle panel and air intake. (nearside)
www.sas.org.uk
www.the-ace.org.uk
Offline NickB91
Re: 2 aeirals?
« Reply #4 on: 15 October 2009, 14:32 »
Thanks for all the tips, they both look pretty factory fitted and yeah it is electric at goes up when i turn on the radio and down when i turn it off.
Offline VR6-Joe
Re: 2 aeirals?
« Reply #5 on: 15 October 2009, 14:58 »
If there's only one wire going to the head unit then it's just the power wire from the wing and into the car, which can be cut/disconnected and then the aerial can be removed from the wing.
The actual aerial cable itself should go from the back of the head unit up to the roof aerial and won't need to be touched unless it hasn't been connected, what's the radio reception like?
Re: 2 aeirals?
« Reply #6 on: 15 October 2009, 15:16 »
Electric aerial should and will have 3 wires, earth, power and feed.
Offline NickB91
Re: 2 aeirals?
« Reply #7 on: 15 October 2009, 16:23 »
Just had a good look at both aeirals and yeah the front wing is all wired up with 3 wires and the roof just has a wire coming off it with a plug, need to get re wire it, how difficult is it to use body filler on the front with and smooth it over to make it look like nothing was there?
Offline VR6-Joe
Re: 2 aeirals?
« Reply #8 on: 15 October 2009, 16:26 »
You'd need to weld a piece of metal behind the hole and filler over the top
You can get a aerial blanking grommet from VW for less than a quid :)
There's a person that sells them on ebay for about a fiver lol
Re: 2 aeirals?
« Reply #9 on: 15 October 2009, 16:29 »
I would get rid of the roof aerial, the signal on mine was crap.
