Author Topic: Heated seats clicking noise....  (Read 2374 times)
Offline Bazzer
« on: 15 October 2009, 11:42 »
So, last year the passenger seat made a fairly alarming noise, like a 'sizzling' kinda thing. As winter turned into summer I forgot about it, but when I switched them on low heat today I found that both now make the noise.
I'm fairly sure it's the seats making the noise, not the dash, and I'm reasonably sure it's a relay clicking on and off lots. I have fiddled with the heater switch, and it seems to be when the seats have reached the temperature they're set to, they fizz a bit. So, when you have them set to '2', after about 5 mins the noise will occur. If you turn them up to '3', the noise goes, but returns a short while later. If you turn them down a bit, again, it goes but comes back.
So I wonder if the relay that controls the heating elements might be a bit iffy? I should imagine there would be a level of hysteresis built in to stop the control system doing it's 'on-off-on-off' thing a lot? Anyone know more about this than me? Anyone solved it? Cheers  :smiley:
Bazzer
Offline VR6-Joe
Re: Heated seats clicking noise....
« Reply #1 on: 15 October 2009, 12:00 »
Think you'll find this is normal, think the relays click to inform you that the heated seats are in fact working lol.
My VR6 Highline does the same and the seats heat up fine so I'm hoping that this is the case :laugh:
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline Bazzer
« Reply #2 on: 15 October 2009, 12:20 »
No no Joe, they're not just clicking, they're buzzing. Like a relay being contacted "on off on off" really quickly, but only as they reach temp.
They never used to do it, they always just warmed up and were pretty much silent.
Bazzer
Offline VR6-Joe
« Reply #3 on: 15 October 2009, 12:51 »
Ooh I see what you mean now, maybe the relays need replacing?
adamrob69
« Reply #4 on: 15 October 2009, 12:58 »
i get the same noise. Only happens when the seat is up to temperature. All i do is get the seat warm then turn them off again lol.
To me it sounds like an electrical noise, and i though it was coming from the actual wiring in the seat, but it is doing it on both my seats. its sounds like a loose electrical connection, where theres a spark trying to cover the gap.
When i bought the topic up couple of months ago i got no replys :/
Offline Bazzer
« Reply #5 on: 18 October 2009, 14:04 »
Got the haynes manual out and looked through for the control unit or anything about the seats. Was probably as much use AS A F**IN seat that thing. Worst £20 I have spent. In fact, next time I'm over there (they are close by) I'm going to tell them what a useless piece of crap that manual is.
Anyway.... Does anyone know where the control unit is? I'm going to guess it's not behind the switch.
Bazzer
adamrob69
« Reply #6 on: 18 October 2009, 15:41 »
There wont be a control unit, it will be a control circuit.
Im guessing here, but i would say there is some sort of potentiometer in the dial switch on your dash. That will vary the voltage going to the heated pads in the seat. The higher the voltage, the hotter they get etc. I wouldnt of thought there would be a relay in the circuit, but i may be wrong. Also im not sure if there would be a temperature switch, again i dont think so but may be wrong.
Offline justalex81
« Reply #7 on: 18 October 2009, 15:56 »
looked on elsawin and all i could find was this. hope it helps
« Last Edit: 18 October 2009, 15:58 by justalex81 »
adamrob69
« Reply #8 on: 18 October 2009, 16:37 »
thats perfect, dont supose you could do a print screen and send it, i carnt quite read a few parts.
Offline justalex81
« Reply #9 on: 18 October 2009, 16:44 »
email sent buddy
