Author Topic: 2.0 8v  (Read 1616 times)
Offline johnson6672
2.0 8v
« on: 14 October 2009, 20:35 »
Someone please correct me if i am wrong but to make a 1.8 8v a 2.0l 8v it is pretty much just a case of changing the bottom end and blocks but you can retain the 1.8 8v head? or is it just easier to put the whole engine in?
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
Offline Diamond Hell
  • Opinions я Us
Re: 2.0 8v
« Reply #1 on: 14 October 2009, 20:49 »
Keep the PB head and you keep the OEM injection system on the car.
The 2E/AGG has different shaped ports, so the inlet doesn't fit up.
Offline johnson6672
Re: 2.0 8v
« Reply #2 on: 14 October 2009, 20:52 »
Just the person i hoped would answer, so which bottom end and block would i need from a mk3 etc?
My mk2 is a PB.
Offline e11ie
Re: 2.0 8v
« Reply #3 on: 14 October 2009, 20:53 »
You should find everything you need to know on here! I found it very helpful...just finishing my conversion! :smiley:
http://www.bailey.org.uk/engine-conversion/
Offline Mr Blue
Re: 2.0 8v
« Reply #4 on: 14 October 2009, 20:59 »
Just picked up a 2.0 8v today. Well pleased with the engine performance :smiley:
  • Opinions я Us
Re: 2.0 8v
« Reply #5 on: 14 October 2009, 21:01 »
2E cheapest.
AGG has a crank sensor, which could be useful if you want to put a proper management system on it at some point.
Offline johnson6672
Re: 2.0 8v
« Reply #6 on: 14 October 2009, 21:03 »
Cheers just had a quick scan though there, i will have to start scanning the breakers near me now. Think i will go simple and have a 2E then.
Offline Ben Lessani
Re: 2.0 8v
« Reply #7 on: 14 October 2009, 21:42 »
Do you not also need the dizzy adaptor ring from TSR - or is that EV specific?
Re: 2.0 8v
« Reply #8 on: 15 October 2009, 10:24 »
depends on the management you use, if you use carb/k-jet you need the ring as you have to use your old dizzy, plus swap the 2.0 dizzy gear over. if digifant you cause the 2e dizzy as it works just the same.  If you get an AGG you need to swap the dizzy for a 2e one, as the AGG uses a signle trigger dizzy and the mk2 digi needs a 4 trigger one.  However you may be able to swap the trigger window over from your pb dizzy
Offline johnson6672
Re: 2.0 8v
« Reply #9 on: 16 October 2009, 22:49 »
I have a  PB so i thinkiwill go for the 2E and keep it simple for now.
