Author Topic: handbrake light stays on  (Read 1813 times)
Offline patty
« on: 14 October 2009, 12:31 »
hi guys,
any ideas??????
went to work in the car yesterday and the handbrake light stays on.....(the handbrake is off)
i took the cover off this morning and checked the wireing /connector and the switch,all seem fine.
is there anything else i could check????
cheers in advance
pat.
1996 black 5 dr 2.0 gti 16v
gtigolfthree
Re: handbrake light stays on
« Reply #1 on: 14 October 2009, 12:38 »
There is also a switch on the brake fluid reservoir
Offline Mikester
  • Civic Type R
« Reply #2 on: 14 October 2009, 12:42 »
Could be low brake fluid.
Or could be that you have more that 1 abs fault.
Your abs light should come on when you start the car, then go off after a few seconds.
If it doesnt light up at all when you start the car this indicates that the bulb has blown, or been removed to hide a fault. And the handbrake light is now warning you of 2 abs faults.
Offline patty
« Reply #3 on: 14 October 2009, 12:48 »
thanks guys,
i will check both later,
its at work at the mo getting a new windscreen fitted!!!!! grrrrr  that's another rant for another day....lol
cheers
pat.
Offline Baskey
« Reply #4 on: 14 October 2009, 12:59 »
i have this also. My abs light is on aswell.
What possible abs faults are there, multi sensor??
gtigolfthree
« Reply #5 on: 14 October 2009, 15:25 »
http://www.golfgtiforum.co.uk/index.php?topic=57396.0
Offline patty
« Reply #6 on: 15 October 2009, 11:02 »
well guys mine seems ok now :smiley: :smiley:
there is a plunger type thingy....lol  in the brake fluid res that was just a little stuck.(it's like a blue dip stick )
cleaned it so it now moves freely,and the light has gone out.
is there supposed to be a cap/lid type thing to stop it comeing through the top of the res though???
as mine now comes through the top of the res.....i cant remember seeing it do that before.
cheers
 all
pat.
gtigolfthree
« Reply #7 on: 15 October 2009, 11:13 »
Mine has a little rubber bung thing on it.
Offline popleyruss
« Reply #8 on: 15 October 2009, 11:25 »
Someone silicon seald mine for sum reason got another cap from a breakers and mine is still on
Just plain dubbin
