Author Topic: name that part 1.4 mk3  (Read 859 times)
Offline Sonic2
« on: 14 October 2009, 08:58 »
to the right of the dipstick tube (lower down) there is a cylender type part, is it a fuel filter? (100% guess).
Looks like something that should be changed periodically, owned the car 3 years and thought it might be time to change it?
gtigolfthree
Re: name that part 1.4 mk3
« Reply #1 on: 14 October 2009, 09:27 »
Picture please.
Offline Sonic2
« Reply #2 on: 14 October 2009, 09:38 »
Its not easy to take a picture of, as it sits under a manifold, but the link here: http://www.golfgtiforum.co.uk/index.php?topic=131854.0  shows a picture of the dipstick tube, follow that down and its to the right of the tube...
Offline Mikester
  • Civic Type R
« Reply #3 on: 14 October 2009, 10:26 »
Oil filter. lol
« Reply #4 on: 14 October 2009, 11:13 »
no the oil filter is on the front. the cylinder sounds like it could be the block breather?  Or perhaps the oil catch cylinder that is sometimes fitted inline with the block breather pipe. follow the pipes from it, if it pops into the bottom of the airbox then yeah its the breather/catch tank. shouldnt need to touch it unless its blocked, if it was you would see excessive crankcase prtessures and blowing oil out of all the seals. also if you take top hapf of airbox off and run the engine, you should see/feel crank case fumes come out of the pipe.
Offline Len
« Reply #5 on: 14 October 2009, 11:14 »
Try looking on vagcat.com
Doesnt give pics but expanded view of parts and gives numbers.
www.sas.org.uk
www.the-ace.org.uk
Offline Sonic2
« Reply #6 on: 14 October 2009, 11:57 »
that's it, breather/catch tank, as it goes to the bottom of the airbox -thanks for the answer  :cool:
Just wanted to be sure I didnt need to be replacing in any service intervals, as it looked like something that resembled a filter.
