Author Topic: stereo wiring problems  (Read 1076 times)
Rain
« on: 24 September 2004, 10:43 »
HELP!
trying to install stereo in my gti and come across something odd
red = live(constant)
Blue/white = (Dash Lights feed)
Brown = Neutral(Ground)
white/yellow might be orange as its a little faded = constant 5volts no more no less even when ignition is on and off.
is this the ignition feed? does a mk2 actually have one :S if its not the ignition feed does anyone know what it is?
Blue MK2
Re: stereo wiring problems
« Reply #1 on: 24 September 2004, 10:49 »
that white and yellow i think is your memory, not sure where that goes myself
Connect the red to your heater switch wire (red and black)
Rain
« Reply #2 on: 24 September 2004, 10:53 »
thanks that seems a good idea live and neutral are fine there there along with the dash lights wire its just that third wire didnt no what the hell it was for and at 5v's its useless ill pull the heater switch out later and solder an extra cable to it for ignition live.
Thanks Blue :D
