Author Topic: steering has a mind of it own ***PICS ADDED***  (Read 6343 times)
Offline Ashley
Re: steering has a mind of it own ***PICS ADDED***
« Reply #30 on: 18 October 2009, 22:56 »
are both of your track rod ends the same? because they're both supposed to be like the 1 you've got pictured
my only other thought is maybe a bent subframe or something structually bent because it sound like you're doing everything you could do to try and fix it  :undecided:
Offline gor131-x
« Reply #31 on: 18 October 2009, 23:00 »
the subframe looks fine and so do both track rod ends,its was the tracking guy who said the track rod on passenger side is bent?
im going to change wishbones and track rods when funds allow and then see how it goes,until then,its only a minor shake and a minor pull to the left and ill just put up with it!
thanks guys,you've been really helpful
Offline Len
« Reply #32 on: 19 October 2009, 09:15 »
If CV is clicking turning right then its passenger side.
www.sas.org.uk
www.the-ace.org.uk
Offline axewielder
  • 95 dragon 8v
« Reply #33 on: 19 October 2009, 13:06 »
havwe you checked wheel nearing in relation to vibrations, might be worth checking cvs too
Offline gor131-x
« Reply #34 on: 19 October 2009, 21:16 »
wheel bearing would make a noise wouldnt it? theres no noise coming from eitehr side and yeh the cv boot sounds knackere by the looks of it if its making a noise when i turn right
Offline axewielder
  • 95 dragon 8v
« Reply #35 on: 20 October 2009, 10:11 »
vibration/noise same thing
Offline gor131-x
« Reply #36 on: 20 October 2009, 19:37 »
then a wheel bearing could be an option to consider,would it help if i told you that its worse in the morning when i start it and once warmed up,the shaking decreases a lot
