Author Topic: steering has a mind of it own ***PICS ADDED***  (Read 6353 times)
Offline gor131-x
Re: steering has a mind of it own
« Reply #20 on: 18 October 2009, 05:25 »
right here are the pics of the passenger side track rod end
and my golf mk3
and my other ride
Re: steering has a mind of it own ***PICS ADDED***
« Reply #21 on: 18 October 2009, 10:04 »
Off topic, looks like your cv boot is leaking
Offline bored_Welsh_lad
« Reply #22 on: 18 October 2009, 10:34 »
mine pulls slightly to the left and i've been laser aligned too...
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Offline Cable
« Reply #23 on: 18 October 2009, 13:06 »
i cant see the bend
VW BUSH
« Reply #24 on: 18 October 2009, 13:24 »
+1
Offline harlemex
« Reply #25 on: 18 October 2009, 13:33 »
ref; shaking - get your rear wheels balanced.
Offline AudiA8Quattro
« Reply #26 on: 18 October 2009, 13:43 »
The track rod end is supposed to have a 'bend' in the casting.
Offline gor131-x
« Reply #27 on: 18 October 2009, 18:01 »
right so:
1.get the rear wheels balanced
2.the cv boot has no rips or anything,so where could he leak be coming from,ill leave it a few days as i did spray a lot of wd 40 when opening the track rod ends
« Reply #28 on: 18 October 2009, 19:28 »
I would say the clip has failed.
Offline gor131-x
« Reply #29 on: 18 October 2009, 21:04 »
you mean the tie clip hlding it? so do i just take that off and put another one on? i noticed today when i turn right,its makes a clicking noise so is that the passenger side cv or driver side?
