Author Topic: fan switch  (Read 1522 times)
Offline Rick#55
  • Golf GTI 1.8T AGU + Honda Fireblade + Ducati 748
fan switch
« on: 11 October 2009, 22:03 »
Hey guys, my fan switch is playing up, well, its not really playing up as such, it works but only on full tilt, so i can either have no air or blast your face off, are they removable or do i need a whole new dash unit console?
Wise man once say:<br /><br /> \"man who fart in bath, makes bubbles\"
Offline northeast_gti-t
  • "1.8T AGU"
Re: fan switch
« Reply #1 on: 11 October 2009, 22:12 »
is it climatronic or manual? if its the manual set up it could more than likely be a faulty resistor for the heater blower
2000 Mkiv GTi 1.8T AGU
Offline Rick#55
Re: fan switch
« Reply #2 on: 12 October 2009, 16:47 »
manual, 4 settings, but only works on setting 4.
Offline Rhyso
Re: fan switch
« Reply #3 on: 12 October 2009, 16:48 »
then its as Matt said - faulty resisitor.  Not 100% sure where its located mind  :undecided:
Offline richw911
Re: fan switch
« Reply #4 on: 12 October 2009, 16:52 »
Taken from another forum:
First off you dont need to take your glove box out as many other how to's suggest.
Under the glove box on the far left  you will find a couple of plastic screws holding some foam trim in place take these out and pull the foam to one side.
Pull out the connector with 4 wires in it, then undo the 2 gold screws with either a 6mm socket or philips screwdriver the resistor pack will now fall out.  :smiley:
Offline Rick#55
Re: fan switch
« Reply #5 on: 12 October 2009, 16:58 »
nice one thanks guys, i take it these resister packs are available from main stealers to replace?
Offline richw911
Re: fan switch
« Reply #6 on: 12 October 2009, 17:03 »
Yep. this sites gives the part number as :  1J0 907 521
http://shop.vws.me.uk/vw-volkswagen-golf-mk4-air--con-blower-motor-resistor-295-p.asp
But check to make sure before you buy one  :wink:
Offline Rick#55
Re: fan switch
« Reply #7 on: 12 October 2009, 17:41 »
ah, just found the problem, i think its related to when the pollen filter cover was broken and let water in! the last owner was such a bell end and left these little jobs that needed doing for me to find!!
Offline T_J_G
Re: fan switch
« Reply #8 on: 12 October 2009, 18:06 »
Methinks you need a new one of those :P
